Z1000 A1 rear wheel spacer
THEMACCLADS
#1 PostAuthor: THEMACCLADS » Mon Jan 08, 2018 9:58 am
Hello. I’m after part number 42032-070
It’s the top hat spacer.
Thanks.
Beer and Sex and ChipsNGravy - It's all a Macc Lad needs.
Yellow
Re: Z1000 A1 rear wheel spacer
#2 PostAuthor: Yellow » Mon Jan 08, 2018 6:45 pm
i might have one....
Yellow
#3 PostAuthor: Yellow » Mon Jan 08, 2018 7:15 pm
Is this the one???
[img][img][/img][/img]
THEMACCLADS
#4 PostAuthor: THEMACCLADS » Tue Jan 09, 2018 10:12 am
No, but thank you. Appreciate your help with photo :D
It’s the spacer with one shoulder that sits on the sprocket side.
Yellow
#5 PostAuthor: Yellow » Tue Jan 09, 2018 12:25 pm
Ok Cheers...
THEMACCLADS
#6 PostAuthor: THEMACCLADS » Tue Jan 09, 2018 1:46 pm
Sorry... disc side.
The diagram in the z-Power booklet is misleading.
Spacers 4 And 24 are pictured wrong way round.
Better picture on cmsnl.com website.
:shock:
walshyco
#7 PostAuthor: walshyco » Tue Jan 09, 2018 5:01 pm
You may want to specify, wire wheels or alloys because I believe they are different sizes, I got the dimensions and had one made, it was easier. Good luck.
THEMACCLADS
#8 PostAuthor: THEMACCLADS » Tue Jan 09, 2018 10:40 pm
Good tip that Cheers for “helping the aged” :D
Wire wheels.
8 Valve Mark
#9 PostAuthor: 8 Valve Mark » Wed Jan 10, 2018 11:15 pm
i have a couple of top hat spacers of vague kawasaki origins,off hand 30mm end to end n 17mm inner diameter (STD kawasaki spindle size).i also have one like yellow offered n could be machined down to fit,it's maybe wider end to end but only by 3 or 4 mm,not sure as I'm in cloudy Spain so can't be exact. pm your details n I'll post you a couple to f'about with.. probably about next wed/Thurs.
THEMACCLADS
#10 PostAuthor: THEMACCLADS » Thu Jan 11, 2018 8:10 am
Thanks for the offer Mark. Very helpful.
Managed to find and order a NOS one this morning whilst browsing over coffee.
Few nice little bits on full throttle projects.com
Thanks.
8 Valve Mark
#11 PostAuthor: 8 Valve Mark » Sat Jan 13, 2018 5:18 am
good you sorted out mate. post up a pic n the dimensions incase my spare ones are of use to a fellow zhead...ride safe.. :blah
Users browsing this forum: No registered users and 1 guest
