GPz1100 starter clutch bits
MDM
#1 PostAuthor: MDM » Mon Dec 09, 2019 11:16 am
So, having failed to find all of the bits :roll: , I've got the ring gear but need the bit that bolts onto the back of the rotor. I have springs and replacement rollers, but need the body and the steel shim-thing too.
Although I can guarantee that as soon as I get the replacement parts my originals will turn up, which is why I've ended up with two complete clutches and two complete alternators...
Z650/1100 turbo, GPz750 rolling resto, Z650 restomod
MDM
Re: GPz1100 starter clutch bits
#2 PostAuthor: MDM » Thu Dec 12, 2019 8:52 am
And, while I've ordered the shims, needle roller bearing and washers required, as they're still available as new parts, the body of the starter clutch isn't stocked / made any more... :( :roll: :sad
#3 PostAuthor: zed1015 » Thu Dec 12, 2019 2:16 pm
I've an 1100 Unitrack starter clutch body, thrust washer, bolts, springs, plungers and rollers.
Come take it .. FOC..
MDM
#4 PostAuthor: MDM » Fri Dec 13, 2019 8:55 am
Ooh, awesome, thanks Rob! I'll drop you a PM ;-)
