cylinder head
DavidZ1R
cylinder head
#1 PostAuthor: DavidZ1R » Wed Jan 25, 2012 6:46 pm
Bit of advise please, took the head off my 250 engine, the pistons and head are covered in carbon, got new pistons and rings, can I use a wire brush on a drill to clean the head, or is that a big no no ?
#2 PostAuthor: Pigford » Wed Jan 25, 2012 6:51 pm
Don't use a steel wire brush - too agressive... :??
Soft brass is OK - or carefully scrape with a flattened copper tube or summink softer than alluminium if possible :wink:
#3 PostAuthor: zed1015 » Wed Jan 25, 2012 6:58 pm
Pigford wrote:Don't use a steel wire brush - too agressive... :??
+1 :up
LTD Project
#4 PostAuthor: LTD Project » Wed Jan 25, 2012 7:00 pm
Wire brush and dettol.... :lol:
You don't say how bad (caked hard) it is but if not too bad then you could try some fine(ish) wire wool and redex, dont forget the latex gloves.
KZ1000 B4 under light restoration.
sid123
#5 PostAuthor: sid123 » Wed Jan 25, 2012 7:15 pm
Soak in nitromores paint stripper then rinse off - no risk of scratching and comes clean
Sid
whoosh im gone
