Don't suppose anything else will fit or could be bastardized into delivering more than standard
Regs, Will
Jeff Saunders wrote:The oil pump on my turbo was optimized by lapping the sides of the case to get the tolerances as tight as possible.
spondonges wrote:I read somewhere , and I wish I could remember where !! that the pump off a GPz1100 is a greater output owing to the fact it has an oil cooler as standard ...
Jeff Saunders wrote:The turbo bikes run VERY hot. What ignition setup do you have?
Users browsing this forum: Robw and 63 guests
