Z1 high output oil pump
#16 PostAuthor: zed1015 » Mon Jun 25, 2012 8:08 pm
Big Fluff wrote:I run 15W-50 semi synthetic.
Regs, Will.
I run Rock oil TRM20/60 in the Drouin
Have you tried that ?
Formulated for roller cranks :wink:
Jeff Saunders
#17 PostAuthor: Jeff Saunders » Mon Jun 25, 2012 8:44 pm
I run 20w/50 mineral oil in my bike - a motorcycle specific brand called Spectro which you don't have in the UK.
Mine is a similar setup.
Wiseco 1200cc 8:1 turbo pistons.
Stock cams set at 110/114.
37mm exhaust valves
42mm HSR carb - 37.5 pilot, 230 main jet, 8DDY01-97 needle
Modified oil pump
MRE lockup clutch
welded crank, HD studs, etc.
The bike is currently running 8 degrees of retard (32 degrees full advance) - but I change this depending on the weather - I will run 12 degrees retard on a hot steamy day.
I only run around 7-8 psi of boost - none of the fuel around here is good enough for more boost without adding an octane booster.
I've owned the bike around 10 years now - not that it's been on the road each year, but it has enough miles on it now to be fairly comfortable with the setup.
Big Fluff
#18 PostAuthor: Big Fluff » Tue Jun 26, 2012 6:58 am
Regs, Will.
Sotckist Rob?
Do you order by the tub :wink:
#19 PostAuthor: Ginger Bear » Tue Jun 26, 2012 7:56 am
# 104
#20 PostAuthor: zed1015 » Tue Jun 26, 2012 11:09 am
Big Fluff wrote:
Regs, Will.
Sotckist Rob?
I got it from local hydraulics supplier as i noticed they sold Rock oil compressor oil so he ordered me a box of four ( 16 litre) as that was the smallest order they could get.
Cost £100 which works out much cheaper than the £40 per 4 litre i found previously.
