tick over stall(and thanks big green bus)
captaincaveman
#1 PostAuthor: captaincaveman » Thu Aug 16, 2012 12:46 pm
Got some fresh fuel in the old gal, she wouldnt start, did what big green bus said to prime the system and off she went, problem now is she ticks over but at certain times if you blip the throttle she dies(or sometimes theres a split second lag), the tick over is at about 700ish. if you hold the throttle a little she can rev everytime.
My obvious thought is to turn the tickover up a bit, but wheres the screw on these, im assuming its like normal carbs with a little screw or wheel thing?
Jay
81 GPz1100 B1
Mark Tiller
#2 PostAuthor: Mark Tiller » Thu Aug 16, 2012 3:50 pm
tickover shoud be 1200 ish
07962421462
#3 PostAuthor: zed1015 » Thu Aug 16, 2012 4:30 pm
700 rpm tickover is too low.
On a well set up motor 1000 rpm should be about right.
jimmock
#4 PostAuthor: jimmock » Fri Aug 17, 2012 5:24 am
zed1015 wrote:700 rpm tickover is too low.
I am surprised it ticks over at all at 700 rpm !!!!
Jimmock. :wnkr
I hate people I don't like !
captaincaveman
#5 PostAuthor: captaincaveman » Fri Aug 17, 2012 9:03 am
yeah it seems to be ticking over just about stalling level, think thats why when i touch the throttle sometimes it stalls, i cant find the screw to adjust it?
Jay
81 GPz1100 B1
big green bus
#6 PostAuthor: big green bus » Sun Aug 19, 2012 7:17 am
make sure the wire is attached to the the tick over scew (yellow if I remember), also check on the bottom of the EFI sensor for the two LED lights the green should be on with the throttle closed and the red at full throttle. Also make sure you have no air leaks from the airflow meter to the airbox (put insulating tape around the end of the flow meter if you are not sure) if there is a leak the air will not be drawn the the meter and not enough fuel will get through.
captaincaveman
#7 PostAuthor: captaincaveman » Sun Aug 19, 2012 10:59 am
big green bus wrote:make sure the wire is attached to the the tick over scew (yellow if I remember), also check on the bottom of the EFI sensor for the two LED lights the green should be on with the throttle closed and the red at full throttle. Also make sure you have no air leaks from the airflow meter to the airbox (put insulating tape around the end of the flow meter if you are not sure) if there is a leak the air will not be drawn the the meter and not enough fuel will get through.
ok thanks, will do :D
Jay
81 GPz1100 B1
Users browsing this forum: No registered users and 102 guests
