starter motor problem.
on my klr the electric start will not work , have put cable from starter motor on to batt plus and it turns over , have also put on a new starter soeniod, checked wires in switch housing and all look ok, what else should i be checking
bunny, try this if you have a multimeter connect it to the two wires that go to the starter button, press button and look for continuity when pressesd, i have seen loads of carboned/dirty contacts over the years, if this is the case remove gubbins fron switch gear, and dress up with a bit of fine emery/wet an dry, squirt a bit of contact cleaner/brake cleaner on then reassemble and recheck, hopefully you will be back to normal, hope this helps, tricky.
Users browsing this forum: No registered users and 100 guests
