Valve Timing - Just Checking
#1 PostAuthor: ZedHead » Fri Apr 19, 2013 4:17 pm
Gents - I am just double checking my valve timing because I have a stating problem when the engine is hot. Can you confirm I have this right on the exhaust side? The inlet is lined up with the 28th pin mark
tricky
#2 PostAuthor: tricky » Fri Apr 19, 2013 5:06 pm
hi, would like to see a pic of both the chain wheels from the other side, preferebly with the top idler out the way and the gasket removed. i could be wrong from the angle of the pic, but it looks a tooth out to me
#3 PostAuthor: zed1015 » Fri Apr 19, 2013 6:30 pm
Yep! looks about right as long as you've counted 28 pins from the next pin up from the one in line with the timing mark.
#4 PostAuthor: z1bman » Fri Apr 19, 2013 7:13 pm
the markings on the sprockets should be on the r/h side of the sprockets ? yours look to be the wrong way round
