Camshaft half moon rubbers
DogsbolloxofZ1B
#1 PostAuthor: DogsbolloxofZ1B » Sat Jun 29, 2013 8:40 pm
What's the best adhesive that secures the half moon rubbers? I've had a few
Slide out when engine gets hot. I've always used OEM ones but they seem a little undersized recently. Silicone doesn't do the job so I assume its a two pack I need..
Didn't the early version of half moon have a small lip on the cam side?
Mike[/i]
kas750
#2 PostAuthor: kas750 » Sat Jun 29, 2013 8:54 pm
I used black soudal fix all which is a hybrid polymer sealant /adhesive.It worked perfectly on my '73.
wilsonsjw11
#3 PostAuthor: wilsonsjw11 » Sat Jun 29, 2013 9:03 pm
Mike
As stated early half moons had a lip on the cam side.
Loctite 5910 black is a very good instant gasket,they also produce a clear version too.
Regards
Steve
#4 PostAuthor: zed1015 » Sat Jun 29, 2013 9:30 pm
I've never had any come out.
The trick is to make sure the head recess and cam end plugs are totally oil free and dry (use brake cleaner) then use RTV to set the plugs in the head but leave them slightly proud of the head until the RTV sets.
When the camcover and gasket is fitted the plugs will be well and truly trapped in position.
Works every time, even with dodgy pattern ones.
DogsbolloxofZ1B
#5 PostAuthor: DogsbolloxofZ1B » Sat Jun 29, 2013 9:49 pm
Thanks for info, I'm off to shop :D
Cheers, Mike
Kev1R
#6 PostAuthor: Kev1R » Sat Jun 29, 2013 10:00 pm
Or use these:
https://www.z-power.co.uk/merchantmanag ... ts_id=1711
and they don't budge.
Still do all the meticulous cleaning though to remove oil traces and then silicone engine sealant.
DogsbolloxofZ1B
#7 PostAuthor: DogsbolloxofZ1B » Sat Jun 29, 2013 10:08 pm
Kev1R wrote:Or use these:
Exellent idea.
Ta Mike
Users browsing this forum: No registered users and 109 guests
