my 900 has been bored out to 1015 and has standard pistons.
What replacement rings would i need?
thanks
what rings
what rings
keep thoses wheels turning
z1000a1 std rings part no 13008-5012
https://www.z-power.co.uk/merchantmanag ... cts_id=537
https://www.z-power.co.uk/merchantmanag ... ts_id=2194
Re: what rings
zman wrote:my 900 has been bored out to 1015 and has standard pistons.
thanks
I would have thought standard pistons in a 1015 would be rather "slack" ???
Jimmock.
I hate people I don't like !
Re: what rings
jimmock wrote:zman wrote:my 900 has been bored out to 1015 and has standard pistons.
thanks
I would have thought standard pistons in a 1015 would be rather "slack" ???![]()
Jimmock
Did make me laugh though.
jphaynes669
- ZedHead
not sure if its rings as head is being checked out.just wanted the info just incase.
But engine firm said all the evidence pointed to the head but can't find a fault,but are doing a check for cracks.but if not it must be in the bottom end. And as boars are good it must be rings
Re: ..
zman wrote:not sure if its rings as head is being checked out.just wanted the info just incase.
zman,
What actually is the problem?
Rings, bores, heads and now bottom end????
Jimmock.
- z1000puddin
Piston rings.
Here you go.
IMD rings. These are as good as genuine.
Full set STD £99.99
http://www.ebay.co.uk/itm/VINTAGE-KAWAS ... 2328854e12
Here you go.
Full set STD £99.99
