The bolts I am referring to are the two M12 lower engine mounts that uses the Steel "segments " instead of normal nuts.
The threads on one of them are in very poor condition , I want to change them but I have no idea what the thread details are apart from metric fine.
Can anyone help?
Z900 A4/A5 engine mounting bolts thread and pitch
Z1000 MK2
Z1300 DFI
Z1300 DFI
I make it M12 x 1.25 pitch - that's taken from my Z1B and using thread gauges and is 70mm long so take it there is a difference between model numbers.
Zpower only list 1 size replacement bolt for the A4 at M12 x 55 long
https://www.z-power.co.uk/merchantmanag ... cts_id=834
Hope that's of some use.
Wots up DOHC
Just in case its the 'pear shape' nuts as well have a browse on there listings
https://www.z-power.co.uk/merchantmanag ... _20&page=7
Wots up DOHC
jimmock wrote:After reading this thread again.
I'm almost certain that the two bolts in question are DIFFERENT lengths.
and you would be correct
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Users browsing this forum: Bing [Bot] and 124 guests
