Maximum safe size for boring out 903cc. barrels
Lee McEvoy
- Regular Poster
Thinking of putting a few more cc's but want to keep it looking stock 903 on the outside? What s the maximum safe size to go for and is high compression worth it as well? Thanks
Lee McEvoy
- Regular Poster
Lee McEvoy wrote:Out of curiosity, can the thin liners if I took it out to 1045 be managed? Or is it just not worth it. My aim is for an every day rideable bike?
Wouldn't bother myself, there's no real power advantage to be had for an extra 30cc.
Also there's a good risk of the liner spigot (the bit that protrudes below the barrel casting) cracking as that portion is thinner than the rest of the liner and if the borer goes even slightly off centre it can get wafer thin.
Lee McEvoy
- Regular Poster
Lee McEvoy wrote:Sorry for ignorance, but can those big bore and sleeves go into a set of 903 barrels? Am I not then into having to alter cases as well?
Big bore kits complete with liners, would mean the crankcases would have to be machined out - to allow for the extra diameter of the liners. Talk to ray at Debben Performance in Ringwood Hants, (as he is relatively local to you) - for more info.
jimmock wrote:This is the kinda thread that makes me want to go and thrash myself into a coma!!!
Go for it mate.
Why has a simple straight forward re-bore question turned into a full on engine strip ???
Just bore it out to 70mm if you want a nice quick motor with no hassles.
You will feel the difference with a set of 10.25 comp Wiseco's and up a size or three on the main jet.
Anything involving bigger liners (even 1015 liners in some cases) will required the crankcase mouths opening up.
Lee McEvoy
- Regular Poster
