Teardrop Engine mounting nut - which way?
Sam Johnson
#1 PostAuthor: Sam Johnson » Fri Mar 04, 2016 5:59 pm
Just fitted crash bars to my 1977 Z1000A1, not sure which way up the lower teardrop mounting nuts go.
Does the pointed end go into the space first or does the hole end go first with the pointed end pointing to the floor?
Can't find anything on the NET about it.
Thanks in advance.
Sam
#2 PostAuthor: Pigford » Fri Mar 04, 2016 6:01 pm
Points UP - but not end of the world if other way round :wink:
Hobbo
International Rep
yo
#3 PostAuthor: Hobbo » Fri Mar 04, 2016 6:59 pm
Guyzz
Always done it point down and taper outwards
phil
International Rep
Taffus
#4 PostAuthor: Taffus » Fri Mar 04, 2016 8:23 pm
Do I need to know this now I have a "prototype" :D
#5 PostAuthor: zed1015 » Fri Mar 04, 2016 9:09 pm
Hole in first.
Pointy end down.
Sam Johnson
Tear Drop Nuts
#6 PostAuthor: Sam Johnson » Mon Mar 14, 2016 9:51 pm
Thanks for all the info its put my mind at rest.
I could only get them in with the pointed end facing down.
Thanks again
Sam
#7 PostAuthor: z1bman » Mon Mar 14, 2016 10:05 pm
they will only fit one way pointed end down
