Guyz, pretty sure you can use a left hand bracket for the extra caliper on an a4?
pretty much the only diff i can see is the milled in flats where it locates on the fork mounts,anyone confirm this and whether i need to get these milled in or another way to do?Ta Paul J
Right hand a4 caliper bracket
- 8 Valve Mark
Re: Right hand a4 caliper bracket
you're right Paul,they swap right over but like you said; just needs the indent 'spot-faced' using a flat drill bit or milled to suit the contour of the caliper mount on the fork leg..good luck mark
Users browsing this forum: Google [Bot] and 63 guests
