YUASA or MOTOBAT
YUASA or MOTOBAT
I am guessing this has been discussed on here before but my searches so far haven't found it. I need to replace a battery on one of my Z1000's, what are your views on the best battery for being left on an Optimate. recommendations on any battery make welcomed.
Re: YUASA or MOTOBAT
Dunno about "being left on an Optimate".... but YUASA is a better quality product.
Haven't had a problem with either Yuasa or Motobatt.
I have both on Optimates and they have been fine.
Had motobat on my zeds for 9 years with out charging them or them being on optamate
+1 for Motobatt
- SVENLEATHER
Had a Yuasa on my Z1B for 10 years and just gave up the ghost probably would have lasted longer had I checked the levels on it.
+1 Motobatt: I’ve been very impressed at how long they hold their charge, much longer than any other battery I’ve come across. Not so important of course if you’re going to leave the battery on a trickle charger...
2019R1250GS....
1974Z1B, 1975 RD350B
- Mark Tiller
Do you mean YUASA acid battery.
Have a YUASA gel batteries on both my zeds now, which during the winter are plugged into CTEK smart chargers, as the Optimate I had fried the Motabatt battery.
- Fred the Zed
- warren3200gt
Motobat here to, but just wish they weren't yellow!
Optimate fried my Motobatt as well. Just use a normal charger now.
Rob
Rob
Motobatt for no other reason than less chance of dumping a load of acid over my lovely shiny exhausts.
jphaynes669
- ZedHead
Used both, without issues on starting or charging.. If you minimise the drain on any system , you reduce the chance of problems.
Jeff.H
Thanks all for your input
