tank cleaning
keith mayall
tank cleaning
guys I've scrolled through the site for a good tank cleaning method ,ive got 2 tanks z1000a1s ,that have just been painted[which took 6 months] so inside is now filthy.What do you guys recommend,I like the coke and harpic idea but don't know how much ratio harpic to coke,theres rust in the tanks so I will need to get that out as well, not a lot mostly surface rust.I know its been on here before but there's no ratios and types and a layman terms to do it.cheers.
Re: tank cleaning
I just use vinegar if its not heavy rust
keith mayall
Re: tank cleaning
white vinegar,,how much do you put in.
Re: tank cleaning
In the search box, search tank cleaning ,plenty of tips there ,
Re: tank cleaning
It's a 3:1 coke to harpic mix, I used Harpic Max power plus, and cheap full sugar coke not diet.
Good luck
Stu
Good luck
Stu
Re: tank cleaning
40% Phosphoric acid
keith mayall
Re: tank cleaning
I did the phosphoric acid last year, but got flash rust even though I rinsed and put meths in.not wanting to try it with tanks being freshly painted.gping full fat coke route this time.
Re: tank cleaning
keith mayall wrote:I did the phosphoric acid last year, but got flash rust even though I rinsed and put meths in.not wanting to try it with tanks being freshly painted.gping full fat coke route this time.
If it flash rusts you haven't left it long enough..
Throckley Lad
- new poster
Re: tank cleaning
I have used DEOX-C to great effect - cleaned my wife's CBR125 tank perfectly, and it was very bad, including the fuel pump. Used WD40 then 2 stroke mix to keep it from re-rusting until we could fill it with Petrol. This stuff works well on all rusty parts.
