I have found that the nut holding the offset sprocket on my Z900 engine has a tendency to come loose after a few hundred miles. The offending sprocket nut will rotate and actually force its way past the bent over tab washer. I could not believe this at first, however I painted some marks to observe the slow rotation over a period of miles ridden and yes the nut was backing off slowly. The nut was previously tightened using an extension bar. I have now bent over 2 tabs on to the nut in the hope this might have sufficient resistance to prevent the nut backing off.
As a back-up plan I purchased a "lock nut" style sprocket nut from Z-power, I think it is the same item as used on the clutch. Does anyone have a positive experience of using this type of nut to hold the sprocket in place or advice on not using it?
Any comments / suggestions appreciated.
Loose Offset Sprocket
kawasaki_man
Re: Loose Offset Sprocket
Yes! i use the locknut type and also apply a bit of loctite too.
The trouble with some of these offset sprockets is that the spline is too long and doesn't expose enough threads to fully take the nut especially the lock nut type.
The last batch of Talon ones were like this and i've had to machine the recess deeper to prevent the nut loosening.
I always use the zpower locknut on all of mine now never come undone as previous poster the offset sprockets are often a bit thicker
Users browsing this forum: No registered users and 85 guests
