Remove head without disturbing base gasket ?
rickm
#1 PostAuthor: rickm » Mon Oct 11, 2021 10:54 am
1981 Z1000J
I will shortly need to get my valves stems skimmed to enable me to get adequate clearance as a couple are on the smallest shims already and the others are getting there.
Back in the day I would strip this engine and remove barrels etc without much fuss, but I'm wondering whether I would actually need to remove the barrels and could get away without disturbing the base gasket if I'm careful ?
Is that just a stupid idea that would result in oil pi$$ing out everywhere once rebuilt !
H2B GPZ900R
Re: Remove head without disturbing base gasket ?
#2 PostAuthor: Ultim8pc » Mon Oct 11, 2021 10:58 am
Usually you can, but you won't know until you do it.
rickm
#3 PostAuthor: rickm » Mon Oct 11, 2021 11:04 am
Thanks for that.
So it's a bit of a gamble then but not out of the question !
H2B GPZ900R
#4 PostAuthor: Bill P » Mon Oct 11, 2021 2:22 pm
I've managed it a few time's no probs but as the man said you won't know till you've tried sadly
rickm
#5 PostAuthor: rickm » Mon Oct 11, 2021 3:10 pm
Thanks, it's good to know that it can be done if you're careful.
Can anyone recommend somebody to do the head work, preferably not too far from North Birmingham.
I need the valve tips skimmed and was thinking about some porting to improve gas flow, although not sure whether it's worth it if everything else is standard (although I may go big bore at some point).
H2B GPZ900R
#6 PostAuthor: zed1015 » Mon Oct 11, 2021 4:20 pm
rickm wrote:was thinking about some porting to improve gas flow, although not sure whether it's worth it if everything else is standard
Correctly done porting will make a worthwhile difference even on a stock engine.
rickm
#7 PostAuthor: rickm » Tue Oct 12, 2021 8:31 am
Can anyone recommend someone nearish to the West Midlands?
H2B GPZ900R
rickm
#8 PostAuthor: rickm » Thu Oct 14, 2021 10:32 am
OK, how about someone anywhere in the country who can do head work (valve stems and gas flowing) ?
There must be folk on here who do this stuff properly ?
H2B GPZ900R
#9 PostAuthor: Bill P » Thu Oct 14, 2021 2:01 pm
How about Buzzard , think he trades as Buzzwork's. Rebuild's Z1's .
Did me a fantastic job on a rattly GS1000S clutch basket to.
He's down in Kent somewhere i seem to remember. Advert maybe in the club mag to i think.
#10 PostAuthor: Bill P » Thu Oct 14, 2021 2:03 pm
Just had a quick look you can find and message him in the Owner's club member's list
rickm
#11 PostAuthor: rickm » Fri Oct 15, 2021 5:26 am
Thanks Bill :up
I believe he’s based in N London, but is pretty busy.
I’ll check him out.
H2B GPZ900R
needaz1100r
#12 PostAuthor: needaz1100r » Sun Oct 17, 2021 1:50 pm
rickm wrote:Thanks Bill :up
I’ll check him out.
He's in S. West London, Teddington.
Highly recommended.
Mark.
