What do these feed?
Skid Mark
What do these feed?
#1 PostAuthor: Skid Mark » Wed Feb 23, 2022 9:20 pm
Hi all!
I tried fire up the Z today... And I'll try again tomorrow!
Very little seems to light-up or work as it should. However, I came across this. It hangs on the right hand side of the battery box. The R/w and White wires join into R/W and connect into positive on the starter relay. The W/Bk fused wire is disconnected, with no likley wire to connect to, the W/Bl wire is missing a fuse. I cannot find these wires or the holder in the wireing diagram, (but it is a pretty blurred copy) Any idea what they are and what correct fuses are? Or can you confirm if they are not standard? :confu
P
Re: What do these feed?
#2 PostAuthor: Philippe » Thu Feb 24, 2022 4:20 am
Hi Skid Mark
it seems to be an additional fuse box for accessories.
Those were mounted on the Z1000P bikes. I think they're mounted on the Z1R too but I'm not sure about that (it's been a few years since I restored a Z1R, the years you know...).
I think someone changed the original fuse holder for this one.
A Z1 has only one fuse of 20 Amp.
If anyone has an other idea, please correct me.
Skid Mark
#3 PostAuthor: Skid Mark » Thu Feb 24, 2022 10:45 am
Thanks Philippe,
I think you're right, I can't quite make out the text but I think they match up to accessory leads.
They aren't the problem!
Thanks.
P
Users browsing this forum: No registered users and 97 guests
