Hi, was just wondering is it possible to convert a Z1000 chain drive engine to a shaft drive engine.
thanks michael
Z1000st
Re: Z1000st
Sorry my dyslexia kicked in and read the question back to front.
So I have some shaft drive parts left over that I don't need
Gus
Gus
"Set the GRINDER on it"
Re: Z1000st
Yes! But only using the ST/MK2 square cam cover cases or later Z1000J /GPZ cases and relevent parts from the equivalent Shaft drive model of the same engine type..
Early 900 and 1000 round camcover models up to the Z1R D1 didn't have a shaft model in the range so can't be converted.
The difference preventing this is that the transmission covers bolt pattern is different on the earlier engines and the later shaft models bevel gear case doesn't fit.
Re: Z1000st
thanks to Gus and Zed 1015 for your response to the question thats answered that question, so does the cases need to be split to do the conversion.
thanks michael
thanks michael
Re: Z1000st
Hi z1r
yes you must split the cases because you have to change the output shaft.
What engine are you going to use to convert from chain to shaft?
As zed1015 says you'll have to use a MK2 or H engine to convert. The other cases (Z900 or Z1000A1/A2) won't work.
If you use a MK2 or H engine case, you'll need an ST gear change.
I think it will be much easier to find a second hand ST engine, those can easily be found.
Re: Z1000st
Hi philippe,
ive got a few mk2 and j engines but want a shaft drive engine that was the reason for the question as i could not find any shaft drive engines readily available.
thanks michael
thanks michael
Re: Z1000st
Try John Browse motorcycles.
01978 355556
Well known for having Z stuff
01978 355556
Re: Z1000st
Edited- not sure what happened there. Answer to a different post. I’ll get my coat.
Re: Z1000st
ADRIAN H wrote:Ben Day @ vapourworx, overhauled my Z1B carbs, top notch.
http://www.vapourworx.co.uk/
Random
Re: Z1000st
zed1015 wrote:
Random![]()
Having a senior moment, what a plonker. oops:
DeadZedDave
Re: Z1000st
Re:Z1000ST - Twowheelspares e-bay shop has a Z1000 ST bottom end listed at the moment. Looks like all you need..... ?
