650b2 carb issue
DavidZ1R
650b2 carb issue
#1 PostAuthor: DavidZ1R » Mon Jun 20, 2022 6:48 pm
Hi guys, I have an annoying stutter from closed throttle to opening it up, soon goes but annoying, carbs stripped and blown through, and cleaned, notch 3 on needles, all stock jets and air box, only thing not stock is the patten silencers, could it be I need to change the pilots? Tia.
Re: 650b2 carb issue
#2 PostAuthor: zed1015 » Mon Jun 20, 2022 6:59 pm
DavidZ1R wrote: notch 3 on needles Tia.
The needle position is wrong .
On the 650 it should to be 4th from the top so it needs lifting a notch.
Also have you had your choke plunger seats done ?
DavidZ1R
#3 PostAuthor: DavidZ1R » Mon Jun 20, 2022 10:19 pm
Yes you did the plungers, I thought the manual said 3rd notch, will double check, cheers
gray
#4 PostAuthor: gray » Wed Jun 22, 2022 8:53 pm
similar prob for me earlier this summer cured by replacing the advancer unit springs - they had stretched and so when you opened the throttle a bit, it went to full advance straightaway.
gray
DavidZ1R
#5 PostAuthor: DavidZ1R » Thu Jun 23, 2022 5:52 pm
Yes the ignition was next up for me, I replaced the carb boots yesterday just in case, just the same, that's easier than taking the bloody carbs off again.
Users browsing this forum: No registered users and 97 guests
