Voltage at Battery z900A4
Pete D
#1 PostAuthor: Pete D » Thu Jun 15, 2023 11:33 am
Chaps
Having checked the voltage at my battery terminals through a range of engine speeds, I was surprised to note it reads 15.7V at 3500 rpm. Normally, I would suspect a dodgy regulator, but I note (from the Haynes manual) that the Z regulator limits voltage to 15-16V.
Before I replace, could I ask wiser heads if such high voltage is normal on our steeds?
Yes, I have tried a forum search, but no simple answer available!
Re: Voltage at Battery z900A4
#2 PostAuthor: kev edwards » Thu Jun 15, 2023 3:53 pm
Short answer is no, probably regulator rectifier issue.
Pete D
#3 PostAuthor: Pete D » Thu Jun 15, 2023 5:44 pm
Thanks. As I thought….
#4 PostAuthor: zed1015 » Thu Jun 15, 2023 6:17 pm
Should be around 13.8 volts max above around 2k rpm.
Pete D
#5 PostAuthor: Pete D » Thu Jun 15, 2023 9:10 pm
Thanks again.
