Recently purchased gpz1100 a1. Now starts and runs fine, just MOTd. Engine had noisy clatter from clutch side. Have removed pressure plate and found this. I can’t correlate the set up to the supplement manual diagram. I and guessing these two pieces should be one piece?
Rob
Gpz1100 unitrak clutch help
paid up member
Re: Gpz1100 unitrak clutch help
Appears to be parts 92043 and 92026A which are seperate parts..
could the springs be worn out between the clutch outer basket and the outer gear? Buzzard did an article some years ago on his setup for fixing this
gray
thanks guys, yes looks correct Rob, the supplement shows the pusher set up in the box which is where I confused!....
I will remove the basket today and look check. is there a topic link to Buzzards thread??
cheers
Rob
cheers
Rob
paid up member
it was in the 2019 yearbook and there is an article in Classic Motorcycle Mechanics - Feb 2020 according to my "reference library"
gray
Does anyone happen to have the 2019 club mag and can copy the article for me please?
THanks
Rob
THanks
Rob
paid up member
Thanks, its interestin, but i just put up another post.....cant even get the bleedin clutch out!
paid up member
