Hello folks,
I am trying to swop some cam shims through the club service.
I believe Jerry was the contact but I've not had a reply to my DM yet.
Is this service still available?
Thanks Adrian
Cam Shims
Captain Custard
- Regular Poster
Cam Shims
- warren3200gt
Re: Cam Shims
Jerry was last active 11 May so probably hasn't seen your mail yet.
Re: Cam Shims
Hi.
Purchased some shims from KHI when rebuilding my engine during an inspection / leak fix. Are the shims available through the swop scheme genuine or mixed with pattern items?
Re: Cam Shims
BAFF1960 wrote:Hi.
Id have thought they started out as genuine but if it's a swap service we have no real control over what people put back in to replace their swaps so hard to be absolutely definitive. There have been no issues so far in twenty years of running the system
Re: Cam Shims
Hi.
Thanks for that reassuring info.
Re: Cam Shims
BAFF1960 wrote:Hi.
What would you suggest as an alternative system?
Re: Cam Shims
Hi.
The shim exchange system is an excellent idea and seems to work well. I normally only source and use genuine parts for reliability and have no experience of pattern ( shims ) engine parts. I was thinking of using the scheme I was a bit unsure parts provenance.
Users browsing this forum: No registered users and 84 guests
