Cam Shims
Captain Custard
Cam Shims
#1 PostAuthor: Captain Custard » Wed May 15, 2024 9:11 am
Hello folks,
I am trying to swop some cam shims through the club service.
I believe Jerry was the contact but I've not had a reply to my DM yet.
Is this service still available?
Thanks Adrian
Re: Cam Shims
#2 PostAuthor: warren3200gt » Wed May 15, 2024 9:53 am
Jerry was last active 11 May so probably hasn't seen your mail yet.
BAFF1960
Re: Cam Shims
#3 PostAuthor: BAFF1960 » Wed May 15, 2024 1:27 pm
Hi.
Purchased some shims from KHI when rebuilding my engine during an inspection / leak fix. Are the shims available through the swop scheme genuine or mixed with pattern items?
Re: Cam Shims
#4 PostAuthor: chrisNI » Sat May 18, 2024 4:10 pm
BAFF1960 wrote:Hi.
Id have thought they started out as genuine but if it's a swap service we have no real control over what people put back in to replace their swaps so hard to be absolutely definitive. There have been no issues so far in twenty years of running the system
BAFF1960
Re: Cam Shims
#5 PostAuthor: BAFF1960 » Sun May 19, 2024 8:22 am
Hi.
Thanks for that reassuring info.
Re: Cam Shims
#6 PostAuthor: chrisNI » Sun May 19, 2024 9:46 pm
BAFF1960 wrote:Hi.
What would you suggest as an alternative system?
BAFF1960
Re: Cam Shims
#7 PostAuthor: BAFF1960 » Wed May 22, 2024 11:58 am
Hi.
The shim exchange system is an excellent idea and seems to work well. I normally only source and use genuine parts for reliability and have no experience of pattern ( shims ) engine parts. I was thinking of using the scheme I was a bit unsure parts provenance.
Users browsing this forum: moizeau and 50 guests
