Clutch rod oil seal replacement
A4Ade
#1 PostAuthor: A4Ade » Sat Jun 14, 2025 11:28 am
Hi, could anyone tell me if it's possible to fit a new clutch rod oil seal without taking the engine out.on my Z900 A4 please . Tia.
Re: Clutch rod oil seal replacement
#2 PostAuthor: zed1015 » Sat Jun 14, 2025 12:33 pm
Yes! Just remove the sprocket cover, pull out the pushrod and you can hook out the seal.
All the seals on the drive side ( clutch, output shaft and gear selector ) are on the trans cover so as a last resort you only have to remove the sprocket and unbolt the trans cover to get a clear shot at either of them.
A4Ade
#3 PostAuthor: A4Ade » Sat Jun 14, 2025 2:04 pm
Thanks for that, I thought you could but I can't pull the push rod out, it moves about half inch then goes solid. Maybe if I put stillsons on and pull hard enough it might pull the oil seal out with it .
A4Ade
#4 PostAuthor: A4Ade » Sat Jun 14, 2025 2:14 pm
It's ok, put the stillsons on tapped them with a small hammer and out it popped,. just got to get the seal out now. Thanks for your help.
Users browsing this forum: Stugill and 19 guests
