Hello to one and all.
I`m after some advice on sprocket size, my GPZ1100 B1 is running 17" wheels 170/60/17 on the rear, 530 chain and an 18 tooth billet front sprocket.
What I`d like to know is what size rear sprocket should I fit to give me gearing that`s roughly the same as a standard GPZ11?
At the moment it`s a little buzzy at speed, 6000+ at 80 mph.
The front sprocket isn`t very old and was pretty expensive so I`d rather just change the rear one.
Any advice on this is appreciated.
Allan
GEARING?
- Dark Skies
Re: GEARING?
KZ1000-M1 CSR
- Geoff Meager
I,m currently running 17 - 33 630 pitch with 17" wheels on the z1r which is close to the std z9/1000s 15-33 on 18"s. On the drouin i'm going 530 pitch which ideally wants 20 - 39/40 to get close but obviously 20t won't fit on the front so i'm going 19 - 39 or 40. A 530 rear with 39-40 teeth has roughly the same core diameter as the 630,s 33 which is really the smallest you should go before you get chain to swingarm pivot clearance issues.
Users browsing this forum: No registered users and 85 guests
