These are a very fine point brass screw found under the front of the float bowl on some models. I'm overhauling a set of carbs for a fellow vjmc member and have found 3 of the 4 screws with the tips broken off.
I've managed to remove the broken tips from the body, but need 3 new screws. Does anyone either know where they can be bought, or have a set for sale ....please
thanks
Loz
mikuni vm26/28 series mixture metering screws
He who dies with the most toys wins .
- DogsbolloxofZ1B
- Jeff Saunders
Fuel Screws - Pilot Circuit
http://www.z1enterprises.com/ItemDetails.aspx?item=SIK-1157SK
We had a bunch of these made for us in Japan.
- Jeff Saunders
To search, no account is needed. The current version of the web site requires you setup an account when you are adding parts to the shopping cart. While it takes a minute to setup the account, once it's established, it's going to be there for you each time you visit.
In a few weeks this limitation will go away.
