Mk2 twinshock swingarm options
Gus
Re: Mk2 twinshock swingarm options
#16 PostAuthor: Gus » Tue Feb 19, 2019 12:27 pm
zed1015 wrote:
Gus wrote:Crikey :shock:
What if I want to use the standard top mounts?
Gus
If the S/A shock mounts are wider than mounts on the frame you can buy or get made some screw on extensions for the original top shock mounts.
Yes I got some shock mount extensions off here. I was wondering about the shock angle to the swing arm is it just a case of matching the original or maybe going slightly steeper to allow for the smaller wheel?
Gus
"Set the GRINDER on it"
#17 PostAuthor: zed1015 » Tue Feb 19, 2019 1:04 pm
Just go for the same angle to keep it simple.
Laying the shocks will soften the back end but give slightly more travel so spring rate or preload may need adjustment
There's lots of variables though depending on where the bottom mounts are and length of the replacement arm.
Most modern twin shock arms are longer and the mounts correspondingly further back.
This will lay the shocks down slightly and also lower the bike so you may need 10mm or 20mm longer shocks to get the height back but with the arms usually being a wider section the shock mounts also sit higher than stock so sometimes the differences cancel each other out and you get away with stock shock length.
If you are welding mounts to the arm then you can set them where you like.
Just take a measurement from the wheel spindle to a fixed point on the frame before you start for reference of ride height when setting up the new arm.
Gus
#18 PostAuthor: Gus » Tue Feb 19, 2019 1:10 pm
Excellent
Thanks for that.
Gus
trikerdrew
#19 PostAuthor: trikerdrew » Wed Feb 20, 2019 10:06 am
Damn, there are some smart folks on this forum!!
:clap :clap
garyd
#20 PostAuthor: garyd » Wed Feb 20, 2019 8:35 pm
Swirl wrote:
garyd wrote:gsxr600 also goes straight in.
What about 1990 gsxr 750m slingshot, have got one of them here
Not sure..best bet..try it.
Swirl
#21 PostAuthor: Swirl » Wed Feb 20, 2019 10:27 pm
All at the measuring stage at the mo, might try and mot it as it is if it runs, then build the units up so they bolt straight in, rear end, frontend
Swirl
#22 PostAuthor: Swirl » Tue Mar 12, 2019 4:47 pm
Bit of playing today, happy days, chain run looks like it will fit inside the frame to. :D
needaz1100r
#23 PostAuthor: needaz1100r » Tue Mar 12, 2019 5:22 pm
Swirl wrote:Bit of playing today, happy days, chain run looks like it will fit inside the frame to. :D
But it probably won't be easy to line up with the gearbox sprocket like that!
Mark.
Swirl
#24 PostAuthor: Swirl » Tue Mar 12, 2019 7:52 pm
Your right it definitely won't :lol:
#25 PostAuthor: zed1015 » Tue Mar 12, 2019 8:17 pm
Is that wheel a 5.5 inch rim ?
If it is you want and 5/8th offset front sprocket and with the rear wheel true central you want the sprocket carrier face 101mm from the centerline.
That will get the sprocket alignment millimeter perfect and the chain will just slip past the tyre and frame with a few mill clearance.
Swirl
#26 PostAuthor: Swirl » Tue Mar 12, 2019 9:37 pm
zed1015 wrote:Is that wheel a 5.5 inch rim ?
It's only the 4.5" I may source a 5.5" fireblade wheel is the same but I've got this complete so going with this for now, with a 160 tyre, I've also got a offset sprocket from my spare zed engine, somehow I've ended up with 3 engines and one bike :lol:
Thanks for the Info will come In handy :)
