Hydraulic clutch conversion ?
Hi Folks, has anyone ever converted a standard clutch to the above. if so does a kit exist, or parts like a slave cylinder off another another bike. I know a dedicated one will be impossible to find, but willing to do some converting. Its to go on a Z1R . Thanks in advance.
Re: Hydraulic clutch conversion ?
I've done loads using ZXR type slave cylinders on outrigger plates etc but if you want an invisible conversion then there a chap called Falk Stumm in Germany who makes one that fits out of sight in the stock sprocket cover.
- Z1streetfighter71
Like Zed said there i used an out riggger plate and a gsf1200 slave as i had one on my Bandit 12 i bought a Nissin master from Webike. Getting the distance in spacing and the length of the push rod right was a chore but works a charm now.
agree with the falk stumm recommendation. I use the same. Also ZRX Master Cylinders look neat and work well.
Talk to Ralph @ Bikerstoolbox he might make you one
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Hi Phil1r
Are you set on a hydraulic conversion or are you just looking to make the clutch easier to use? I asked a similar question earlier in the year (also about a Z1R) and the easiest recommendation was an easy-clutch kit. I've attached my thread - there's also another thread from chrisu linked to that one. I've not fitted one yet (webike were out of stock at the time) but it's one the list of things to do once the weather improves a bit.
viewtopic.php?f=4&t=50633&p=413430&hilit=easy+clutch#p413430
TTFN Grog
TTFN Grog
1979 Z1R (mostly - it's been fiddled with a bit)
1977 Z650B1 - I'll get round to putting it back together one day...
Hi Grog, thanks for that, I will look at the other option as well. I would like to make it much lighter. If possible,
Also trying to keep the bike looking correct.
phil1r wrote:Hi Grog, thanks for that, I will look at the other option as well. I would like to make it much lighter. If possible,
go one better fit a electric shift drum just a button on handlebar
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2026
ZX12-R slave and master cylinder on home made cover plate.
Z1streetfighter71 wrote:Like Zed said there i used an out riggger plate and a gsf1200 slave as i had one on my Bandit 12 i bought a Nissin master from Webike. Getting the distance in spacing and the length of the push rod right was a chore but works a charm now.IMG_2718.jpg
I have a very similar Plate made by Spectra Engineering but using an Oberon Slave Cylinder
then the eazyclutch option would be your best choice I think
Users browsing this forum: No registered users and 161 guests
