Project ?
jonhunt
Project ?
#1 PostAuthor: jonhunt » Fri Dec 09, 2011 4:15 pm
After seeing all the threads I am tempted to start something. I've the engine, well most of it. Z2 thats got a 903 barrel & head. Hopefully whoever did this changed the crank otherwise the comprression might be a bit low :lol: Just got to get everythig else. Leaves alot of scope.
Or i could try to get that old TL125 from my neighbour. :idea:
HARRY4448
Project ?
#2 PostAuthor: HARRY4448 » Fri Dec 09, 2011 9:44 pm
Mr Pigford has a rolling chassis for sale.
In the "For sale" section
#3 PostAuthor: Pigford » Sat Dec 10, 2011 8:21 am
I was "mis-informed" (not intentional tho') :oops:
I do have a Z650 frame + V5 with front ends (a std Z900 & a BANDIT 1200 RWU) with rear end (std Z1000 & BANDIT 600 - 160 section tyre) and tank/tail piece and brakes & down pipes, etc, etc.... :wink:
jonhunt
#4 PostAuthor: jonhunt » Sat Dec 10, 2011 7:16 pm
Put a low bid on that rolling chassis on e bay :roll:
Koreanbaz
#5 PostAuthor: Koreanbaz » Sat Dec 10, 2011 8:19 pm
Pigford wrote:I was "mis-informed" (not intentional tho') :oops:
whats the idea of a bandit swing arm? is it a straight fit?
Life is not a trial run
jonhunt
#6 PostAuthor: jonhunt » Fri Jan 27, 2012 10:24 pm
Well this is the engine in all its gory detail. Interesting the clutch is marked Z2 were they different?
903 barrels
jonhunt
#7 PostAuthor: jonhunt » Wed Feb 22, 2012 8:14 pm
OK so the points housing is shagged & there is no alternator stator or rotor. How much £? :??
jonhunt
#8 PostAuthor: jonhunt » Sun Mar 01, 2015 6:46 pm
Finally managed to get the head off with some help. head was seized on the dowels so the whole lot came off & then drifted the head off the barrels.
Little bit of carbon here! Also a dead woodlouse.
No idea if these are OEM pistons having never stripped on of these before.
#9 PostAuthor: zed1015 » Sun Mar 01, 2015 6:56 pm
Some good progress there.
Looking forward to your next instalment in 2018 :lol:
jonhunt
#10 PostAuthor: jonhunt » Sun Mar 01, 2015 7:04 pm
Yes slow indeed other projects took my interest. I'm going to break this engine I want the head & barrels mine have damaged fins.
