Zebedee wrote:Today was supposed to be about building a rack in the garage and bolting the big vice to the bench, but I took a dislike to the way the carbs were sat and as it lightens the load when swapping the engine over to the other frame, I took them off.
What a mess
Just seen this post.
The right and left pairs of carbs are the wrong way round on the backplate.
It won't make a difference in this case though unless you planned to run without an airbox and fit air correctors.
