Z650 Special...not for the purist.
Re: Z650 Special...not for the purist.
#31 PostAuthor: ADRIAN H » Mon Jun 08, 2020 7:45 pm
Looking brill, you must be chuffed. Would'nt mind one myself. But not sure my back would take it. :D :D :D
Paul Whitehouse
#32 PostAuthor: Paul Whitehouse » Wed Mar 06, 2024 11:06 am
It's been a while since any updates on this one chaps...lots been going on over the last couple of years.
The plan is to, hopefully, have it ready to take over to the IOM for the Manx at the end of August.
Still masses to do but the engine is somewhere near ready to start putting together. Barrels are out to a 64mm bore ready to accept the Wiseco pistons.
The images of the paintset on the bike are with the bike still in mockup form.
The frame and ancillary parts have been powder coated. Paintset is done. Huge thanks to Stig at Stigs Custom paint in Charlwood (nr Gatwick) for the superb job of the paint. I wanted a heavy `70's metalflake and the white stripe to mimic the Kawasaki race bikes of that era.
If it's too loud....too bad.
#33 PostAuthor: chrisNI » Wed Mar 06, 2024 6:16 pm
Looks very smart :jake
sanderz
#34 PostAuthor: sanderz » Wed Mar 06, 2024 6:38 pm
Bike looks well there Paul, that paint is 'tip top' :drool
Wots up DOHC
#35 PostAuthor: deka » Fri Mar 08, 2024 10:26 am
lovely if i had the skill and the money back in the day that is what i would have wanted from my z650
Paul Whitehouse
#36 PostAuthor: Paul Whitehouse » Thu Sep 05, 2024 12:19 pm
Having machined a couple of spacers for the rear wheel spindle, the old girl is back on her wheels.
Has anybody on here fitted a set of Paolo Tarozzi rearsets on a Z650. I ordered a set suitable for the drum brake version and have received some with a really long main fixing bracket…as per the photo. I’m wondering whether I’ve been a bit too keen with the angle grinder and removed the brackets these need to fix to.
I was assuming I would receive a similar set to those I fitted on my Z900.
#37 PostAuthor: warren3200gt » Thu Sep 05, 2024 1:03 pm
Looks like they mount to the (chopped off) rear footrest hangers.
I used Raask rearsets which mount to the existing foot rest frame point and the rear engine mounts.
Then because the levers on Raask are so mickey mouse I replaced them with self made ones and drilled a few holes to make Colin Chapman happy by adding some lightness.
Then added in an extra piece to drop the height and move the pegs back a bit further to fit me better.
PUM 488 June 2023
#38 PostAuthor: zed1015 » Thu Sep 05, 2024 1:26 pm
Paul Whitehouse wrote:I ordered a set suitable for the drum brake version and have received some with a really long main fixing bracket…as per the photo. I’m wondering whether I’ve been a bit too keen with the angle grinder and removed the brackets these need to fix to.
Those you have are for the later 79 onwards models.
Paul Whitehouse
#39 PostAuthor: Paul Whitehouse » Thu Sep 05, 2024 1:28 pm
Cheers Warren, yeah I thought as much.
Ok, these will be returned and I’ll look for a pair of Raask rear sets.
#40 PostAuthor: warren3200gt » Thu Sep 05, 2024 1:38 pm
Paul Whitehouse wrote:Cheers Warren, yeah I thought as much.
Raask levers are absolute rubbish Paul. I pretty much ended up only using the base plates and made up the rest myself.
PUM 488 June 2023
Users browsing this forum: No registered users and 119 guests
