Vibration through the bars.
Monk
#1 PostAuthor: Monk » Mon Aug 31, 2009 6:01 pm
Anyone out there found a way to stop vibes through the bars ?
My hands start tingling after about 10 miles, by 20 miles it is a right pain in the arse (well, fingers really)
Bar snake ?
Rubber engine mounts ?
Fill bars with sand and fit the worlds heaviest bar end weights ?
#2 PostAuthor: Pigford » Mon Aug 31, 2009 6:22 pm
Just answered it yerself Monk :wink:
Lead stuffed in the bars - then you can't see it :!:
floydsz1
#3 PostAuthor: floydsz1 » Mon Aug 31, 2009 6:22 pm
iv'e had same trouble with all my zeds, iv'e put some lead flashing in the bars on my z1a but i cant decide if its any better or not. seems better but i still get it. seems worse at cruising speeds, 70/80mph. Have tried loosening engine mounts and tightening them up again, funny thing is i dont remember it being a problem when i first got one back in the late 70's etc.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
Monk
#4 PostAuthor: Monk » Mon Aug 31, 2009 6:39 pm
Guys
I could ride for ever back then.
I reckon it's down to a life time of smoking and now bad circulation causes the tingling.
bunnysZ
Granny Magnet
#5 PostAuthor: bunnysZ » Mon Aug 31, 2009 6:57 pm
you can buy them cushion grips , , more padded out, stops the vibration , but don't look quite right
#6 PostAuthor: kev edwards » Mon Aug 31, 2009 7:21 pm
cut a rubber fan belt and push as far down into the bars as poss , we used to put fan belts in long hollow cylinders for printing when lathing down a size or two at a metre plus in length they used to vibrate at high speed and the rubber belt acted as a damper , best thing we ever used , so it may help in the bars .
Jumbo
#7 PostAuthor: Jumbo » Mon Aug 31, 2009 7:55 pm
I have had a similar problem and also was never too confident in adjusting my cam chain using the standard adjuster. I have fitted an APE Manual adjuster and feel that the vibration is better.
I might be wrong but it is worth checking.
LE to JOG on a z900
P.U.M.
ted1r
post
#8 PostAuthor: ted1r » Tue Sep 01, 2009 4:45 pm
Bar end plugs, did it on me Z1r.
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
