Z1 head/cams vs. KZ head cams
GregZ
#1 PostAuthor: GregZ » Fri Oct 09, 2009 11:44 pm
Well my new to me 1978 kz1000 project is underway. The 26mm carbs will go to junk box and in place a set of 29mm smoothbores.
I plan freshing up the motor. Hopefully just new rings.
I have a 1974 Z1 head completly rebuilt new guides,seals 3 angle valve job and benched shimmed and of course Z1 cams. Ready to bolt on.
Is there any differance between the Z1 head and the 78 1000 head and cams?? I think I remember the Z1 cams are little better in performance then the kz.
Or should i just have the Kz head rebuilt??
cheerz
gregz
Z1
1965 Corvette
popsA1
#2 PostAuthor: popsA1 » Sat Oct 10, 2009 10:00 am
Heads are interchangeable. I'd use your Z1 head. Check cam lobe faces for wear and pick the best.
A2 1979-80. A1 1980-now
#3 PostAuthor: Ginger Bear » Sat Oct 10, 2009 6:17 pm
I believe the exhaust studs are different sizes. The 1000 head will have 8mm where as the earlier heads would have had 6mm studs fitted, shouldn't be a problem though.
