is that correct? as the fittings for the hjoses to clamp to the cooler available?
H**** oil cooler question
.... see photo ... looks like the fittings are cricular ends that bolt on using two bolts onto the cooler, an o-ring making the seal.
Basically yes, they are flanged to match the cooler with two bolt holes, the tube does extend in to the cooler fittings slightly to positively locate the o-ring.
Have a look for the hoses as well, the hose is usually swaged on and can be removed and replaced with the careful use of a hacksaw.
