Front Master cylinder A2
breakdown
#1 PostAuthor: breakdown » Tue Oct 27, 2009 1:40 pm
I've got a master cylinder for my A2, which I was told had come from an A2. The cylinder looks correct, right shape and going from the diagram in the manual, identical part for part. When I went to order the repair kit I noticed that the dia of the piston is 14mm. Is this correct for a twin disc set-up. If not, any idea's what it might be from. Any info gratefully appreciated. Thank you
tlc
#2 PostAuthor: tlc » Tue Oct 27, 2009 2:27 pm
It`ll be a KZ one then.
There are people that can bore them out, I have a name if you need ? PM if so.
breakdown
#3 PostAuthor: breakdown » Thu Oct 29, 2009 9:31 pm
Tried your man Chris, but no reply as yet. Anybody else know of somebody that can bore out a front brake master cylinder, need it taken out to 5/8.
Cheers Folks
tlc
#4 PostAuthor: tlc » Fri Oct 30, 2009 6:18 am
Patience is a virtue ! Maybe contact RB ?
breakdown
#5 PostAuthor: breakdown » Fri Oct 30, 2009 9:35 pm
Hi Chris,
Your right again, phil contacted and will let me know when he's ready to do it. Thanks for the help, much appreciated.
Garn 1
#6 PostAuthor: Garn 1 » Tue Nov 03, 2009 7:16 pm
Breakdown, the Kawasaki sizes of their early master cylinders are nominally 1/2 & 5/8 inches. I have noticed this is only a "Nominal" size and the 1/2 " is about 11-12 mm and the 5/8" could be about 14 mm. ... Worth a check!
