Hi can anyone tell me if the barrels off a Z1000mk11 will go on my Z1000 D1 (Z1R), the guys says yes as they are both 1015cc.
Cheers Chaps
Z1000mk11 barrels
Gary, here is a list of the models that share your pots,
? KZ1000-A1 KZ1000 (1977)-->CYLINDER/PISTONS/CRANKSHAFT ('79-'80 A3/
? KZ1000-A2 KZ1000 (1978)-->CYLINDER/PISTONS/CRANKSHAFT ('79-'80 A3/
? KZ1000-A2A KZ1000 (1978)-->CYLINDER/PISTONS/CRANKSHAFT ('79-'80 A3/
? KZ1000-A3 KZ1000 (1979)-->CYLINDER/PISTONS/CRANKSHAFT ('79-'80 A3/
? KZ1000-A3A KZ1000 (1979)-->CYLINDER/PISTONS/CRANKSHAFT ('79-'80 A3/
? KZ1000-A4 KZ1000 (1980)-->CYLINDER/PISTONS/CRANKSHAFT ('79-'80 A3/
? KZ1000-D1 Z1R (1978)-->CYLINDER/PISTONS/CRANKSHAFT ('78 D1)
? KZ1000-D1 Z1R (1978)-->CYLINDERS/PISTONS/CRANKSHAFT ('80 D3)
? KZ1000-D3 Z1R (1980)-->CYLINDER/PISTONS/CRANKSHAFT ('78 D1)
? KZ1000-D3 Z1R (1980)-->CYLINDERS/PISTONS/CRANKSHAFT ('80 D3)
? KZ1000-E1 Shaft (1979)-->CYLINDER/PISTONS/CRANKSHAFT
? KZ1000-E2 Shaft (1980)-->CYLINDER/PISTONS/CRANKSHAFT
? KZ1000-G1 Classic (1980)-->CYLINDER/PISTONS/CRANKSHAFT
I'm not sure which model in the list is the MK2 but I would say yes they will fit. Hopefully someone will be along shortly to confirm.
- paul doran
Users browsing this forum: No registered users and 73 guests
