z900 kh500do they share the same brakes
steve f
#1 PostAuthor: steve f » Sat Mar 17, 2007 6:12 pm
does the z900 and the kh500 share the same discs and calipers i think they do but not sure
Garn 1
#2 PostAuthor: Garn 1 » Sat Mar 17, 2007 7:21 pm
SteveF, when you say Z900, are you refering to Z900A4 or Z1 series? I believe they are both different from the Kh500 caliper, however, you may find the Z1 series may fit with respect to front forks holding-bolt centre distances. The KH500 may also have ribs (Cooling?) cast into the body. There were several small changes between these models. For example, the piston/ pad size may be smaller on Kh500.
#3 PostAuthor: Rich » Sat Mar 17, 2007 7:38 pm
http://www.buykawasaki.com/
Check out the part numbers.
steve f
#4 PostAuthor: steve f » Sat Mar 17, 2007 8:16 pm
Garn 1 wrote:SteveF, when you say Z900, are you refering to Z900A4 or Z1 series? I believe they are both different from the Kh500 caliper, however, you may find the Z1 series may fit with respect to front forks holding-bolt centre distances. The KH500 may also have ribs (Cooling?) cast into the body. There were several small changes between these models. For example, the piston/ pad size may be smaller on Kh500.
sorry i did mean the z900 A4 sure they share the same calipers and discs
rickman CRR
#5 PostAuthor: rickman CRR » Mon Mar 19, 2007 1:14 pm
http://www.buykawasaki.com/Scripts/ImgS ... F=P&ilRE=8
KH 500 caliper?......looks like its significantly different to Z900 A4
rickman CRR
#6 PostAuthor: rickman CRR » Mon Mar 19, 2007 1:17 pm
I think that link above shows a H1 model
however
Looks very similar to the A4......
So probably out the same parts bin.
rickman CRR
#7 PostAuthor: rickman CRR » Mon Mar 19, 2007 1:20 pm
same part number as well.
43041-030
steve f
#8 PostAuthor: steve f » Mon Mar 19, 2007 4:31 pm
well wegot there in the end KH500 and Z900 are the same caliper
Are they the same disc ???? 4 bolt fitting
