Surprise Piston's........ Any Idea's Please?
Taffus
#16 PostAuthor: Taffus » Sat Nov 14, 2009 10:20 pm
steve f wrote:had a turbo technics escort rs1600i that kept detonating and eating the head so had it skimmed and stuck 2 headgaskets together and sold it
Hmmm don't think I'll buy anything from you!
#17 PostAuthor: Ginger Bear » Sun Nov 15, 2009 2:40 pm
Pigford wrote:Bear, have a buthcers: http://www.oldskoolperformance.com/foru ... =12&t=1067
Had a butchers Piggy, but all I got was 'The requested topic does not exist.'
# 104
#18 PostAuthor: Pigford » Sun Nov 15, 2009 2:46 pm
:oops: So did I :?:
Take a look in OSP "Projects" @ Fuel Injected Turbo Katana by Katman
Big Fluff
#19 PostAuthor: Big Fluff » Mon Nov 16, 2009 9:27 am
GB. The part No. 4302 on your piston does indeed denote Wiseco 75mm 10.25:1 CR.
They may look like really high comp pistons but as Rich says, the combustion chamber went much deeper on that model, so the compensation was to increase the height of the crowns.
#20 PostAuthor: Ginger Bear » Mon Nov 16, 2009 8:17 pm
Thank's Will, I guess these will work fine in a standard (i.e. not turbo or supercharged) engine? I do hope to run the fuel injection though!
# 104
big green bus
#21 PostAuthor: big green bus » Mon Nov 16, 2009 10:49 pm
you can still run the injection, but you may need to increase the fuel pressure.
#22 PostAuthor: Ginger Bear » Tue Nov 17, 2009 7:32 am
big green bus wrote:you can still run the injection, but you may need to increase the fuel pressure.
Is that a fairly simple job involving that fuel regulator that sit's below the throttle bodies, or is it some major re-mapping job which will cost loads & cause me a lot of grief?
This engine had the injection fitted when I removed it, although I have never heard it running.
You've got me thinking that I should possibly reconsider carbs :??
# 104
big green bus
#23 PostAuthor: big green bus » Tue Nov 17, 2009 10:29 am
i did it with an adjustable pressure regulator and a inlne pressure gauge. it is a be hit and miss as you would need to adjust the throttle position sensor after you alter the pressure to keep the tick over mixtures right. it is a piss about or you could set it up on a rolling road
coldsummer
#24 PostAuthor: coldsummer » Tue Nov 17, 2009 11:01 am
Looks like trip down to Tim Blakemore's GB?
#25 PostAuthor: Ginger Bear » Tue Nov 17, 2009 7:32 pm
Mmmmmm............... sometimes it's best to farm these things out to those with the equipment & the know how.
I think Tim could be getting a visit for sure.
Thanks for the advice BGB :D
# 104
Pasc
#26 PostAuthor: Pasc » Tue Nov 17, 2009 9:02 pm
Bear, you can go down the adjustable FPR route as BGB has mentioned. Another route is to pick up a second hand PC III Power commander of ebay (about £50 maybe less). This can be wired alongside the stock ecu and once you have a dyno read out you'll be able to adjust the fuelling throughout the rev range.
#27 PostAuthor: Ginger Bear » Tue Nov 17, 2009 9:15 pm
Thanks Pasc,
That sounds like a good option, I think I'd still need to buy the parts & give it to someone who knows what they're doing :shock:
Just off to have a quick dabble on ebay :D
# 104
big green bus
#28 PostAuthor: big green bus » Thu Nov 19, 2009 9:07 am
pasc is right some guy on the gpz750 turbo web site has a wiring diagram to fit a power commander and got very good results try that site too
#29 PostAuthor: Ginger Bear » Thu Nov 19, 2009 12:22 pm
GPz750 Turbo site.......... Here I come :shock:
# 104
Murph
#30 PostAuthor: Murph » Thu Nov 19, 2009 1:28 pm
Hi GB my Lawson with a J /GPZ motor runs an 1170 wiseco big bore kit with mikuni 36mm flatsides with no probs whatsoever and the torque is un belevible.
Out on the road you can stick it in top and leave it and it will pull from almost any revs , carbs are worth thinking about . enjoy :wink:
Z9A4, Z1000a1 ZX10B1 ZX10B3 ZZR1100 ZG1200 VOYAGER
