Metric threads - all the same or not?
coldsummer
#1 PostAuthor: coldsummer » Wed Dec 09, 2009 11:09 pm
Having got all my powder coated parts back I started cleaning out some of the packing in the threaded parts and I want to run a tap through them just to give them a final clean but I'm not sure if all metric threads are the same pitch. The reason I ask is that I've noticed an ebay nut seller (!) states the 70's Jap bikes have a fine thread, or something like that, and I really don't want to f*** up the threads by running the wrong tap through. I have a standard metric tap and die kit.
Any thoughts??
Steve Cooke
#2 PostAuthor: Steve Cooke » Thu Dec 10, 2009 12:17 am
Go careful as there are a mixture of thread pitches used throughout, quite a few being metric fine which your standard Tap/Die set probably doesn't have.
GUYZED
#3 PostAuthor: GUYZED » Thu Dec 10, 2009 1:21 am
Bottom yoke 12mm bolts are 1.25 fine pitch.
#449
Z1000A2 Z650B1
wilsonsjw11
#4 PostAuthor: wilsonsjw11 » Thu Dec 10, 2009 5:51 am
Simon
As a rule of thumb anything above M8 is 1.25 pitch M6=1.0 M8=1.0/1,25
But before running any tap through any hole match the tap up against the proposed bolt for that hole ie lay it along side each other and make sure the pitches go in to each other.
Regards
Steve
tlc
#5 PostAuthor: tlc » Thu Dec 10, 2009 6:28 am
Maybe a typo there Steve.
I can`t think of any fine thread M8 threads but commonly M6 are 1.00mm, M8 are 1.25 and M10 are 1.25mm and 1.50mm.
Go to your local quality tool specialist and buy a set of 3 taps of each size. Those being taper, second and finishing taps. These will be a sound investment and will last a lifetime.
4 = 0.7
5 = 0.8
6 = 1
7 = 1
8 = 1.25 or 1
10= 1.5 or 1.25 or 1
12= 1.75 or 1.5 or 1.25
wilsonsjw11
#6 PostAuthor: wilsonsjw11 » Thu Dec 10, 2009 7:42 am
Chris well spotted,MUST OF BEEN THE TIME OF DAY :??
Whats the pitch on the M8 studs for the front axle clamps while were on the subject?
Big Fluff
#7 PostAuthor: Big Fluff » Thu Dec 10, 2009 1:08 pm
If you know what bolt/screw goes where, and you're either fitting new or have spares, then the best way would be to cut a sharp groove lengthways along the threads of the old bolts etc. and use that as a thread cleaner.
Will.
coldsummer
#8 PostAuthor: coldsummer » Thu Dec 10, 2009 2:20 pm
Thanks, as always, for the helpful replies guys. I'll certainly tread very carefully with this.
Magnum1
#9 PostAuthor: Magnum1 » Thu Dec 10, 2009 5:32 pm
Taffus
#10 PostAuthor: Taffus » Thu Dec 10, 2009 7:08 pm
tailiftchris wrote:Maybe a typo there Steve.
4 = 0.7
5 = 0.8
6 = 1
7 = 1
8 = 1.25 or 1
TLC you're our very own "Bernie the Bolt" :D
nigel bessant
#11 PostAuthor: nigel bessant » Thu Dec 10, 2009 7:16 pm
coldsummer wrote:Thanks, as always, for the helpful replies guys. I'll certainly tread very carefully with this.
Or did you mean to say "Thread very carefully"
God I'm good!
Taffus
#12 PostAuthor: Taffus » Thu Dec 10, 2009 7:29 pm
God I'm good!
yes, you "pitched" it just right for whitworths
#13 PostAuthor: ZedHead » Thu Dec 10, 2009 7:35 pm
Get a THREAD PITCH GAUGE like this one.
http://cgi.ebay.co.uk/BSW-IMPERIAL-METR ... 4837004ddb
nigel bessant
#14 PostAuthor: nigel bessant » Thu Dec 10, 2009 7:35 pm
God I'm good!
I can't respond to that for fear of being dubbed the village idiot! But...If I was to respond I'd make a quip regarding boxed dried fruits associated with the age old art of cake making and the like.
nigel bessant
#15 PostAuthor: nigel bessant » Thu Dec 10, 2009 7:50 pm
Might I suggest that you get hold of a "Zeus" book. It's a small booklet that gives loads of information on, apart from other things, thread information, ie pitch, depth, form, as well as tapping drill sizes and reccommended clearance hole sizes. It covers all thread forms and you never know when you might need it for other threads, like Big F*ck Off V8 Yanks! The other thing that is useful is a good quality thread pitch guage. not the cheap ones as these are usually a fettled stamping. I bought my Zeus book at the young age of 17 as a silly little apprentice. It's lasted 33 years and smells of cutting oil!!
