Carbs and Caliper bits
walshyco
#1 PostAuthor: walshyco » Tue Dec 15, 2009 9:05 am
I am after a couple of bits,a set of needle valves for Z1B 28mm carbs,although I only actually need one. I think they are the same across the range including Z1000s.Also I want to put on a twin discs, so any of the parts required I am also interested in. Thanks. Sean.
#2 PostAuthor: kev edwards » Tue Dec 15, 2009 1:47 pm
i may have a needle valve i will lookand let you know.
#3 PostAuthor: kev edwards » Wed Dec 16, 2009 1:34 pm
Hi Sean,i have found a needle valve yours if you want it,just send me your address.
kev
walshyco
#4 PostAuthor: walshyco » Wed Dec 16, 2009 8:42 pm
Thanks for that Kev appreciate your help.Sean.
Users browsing this forum: MikeP and 37 guests
