Z1B front disc bolts
Can anyone advise me of the correct thread pitch for the 8MM X 28MM disc bolts for the Z1B. I am sure it should be 1.25 but would like to be sure before I buy some stainless bolts. These are for the six bolt discs.
Thanks in advance
Mart
Thanks in advance
Mart
hillbilly wrote:im after some myself,a mate of mine is makeing me some,been quoted silly money for the original bolts,and refuse to pay extortionate prices.
I will probably end up getting these when I have some more things to order.
http://www.z1enterprises.com/detail.aspx?ID=3258
The original part is still available from Kawasaki, 92001-104 and costs 347yen each. So genuine is what, $3.80 USD each?
It makes the stainless sets that Jeff at Z1 enterprises sells for $18.50 look very good value unless you're a slave to originality.
I mean, even if you had stainless hex stock on hand and a lathe...why would you even bother making them if they can be bought so cheaply?
Dxyselia rlues, oaky.
http://www2.b3ta.com/youcantspell/
hillbilly wrote:ive just put 12 in the quantity box and it calculates to 222 dollars,its advertised as six.martinz1b.be carefull.false advertising.can we point this out to them.
I put 2 in the quantity box and it came to 37 dollars. I am sure it means 2 x 6 bolts. You would have been buying 72 bolts for $220.
If you aren't in a rush I will let you know what I get when they arrive.
Mart
As mentioned above it's worth trying Inox Jerry used to keep them in stock as club spares but they came from Inox anyway so eventually he stopped keeping them just told people to go direct. It still says in the magazine to contact them for Stainless Disk Bolts, they should have them in stock at a reasonable price.
chrisNI wrote:As mentioned above it's worth trying Inox Jerry used to keep them in stock as club spares but they came from Inox anyway so eventually he stopped keeping them just told people to go direct. It still says in the magazine to contact them for Stainless Disk Bolts, they should have them in stock at a reasonable price.
I have used Inox before. Very good quality gear, but in this case it was cheaper to get them from Z1Enterprises, I also wanted some other bits so the additional postage is negligible.
Hi Guyz, I'm shocked and stunned at the price you guyz are saying these items cost.
I bought a load of metric "fine" from the Guy Middleton (I think he's in Bateley Yorkshire) many years ago. It was more expensive than normal pitch but no where as big as the prices you've quoted.
I know you are all going to slag me to death here, but I personally would consider drilling the hub and rethreading with a 1.25mm helicoil. Much stronger than the original alloy threads.
Does it really need to be a 1.0mm pitch for maintaining its tension ????
Jimmock.
Jimmock.
Jimmock.
I hate people I don't like !
Users browsing this forum: No registered users and 73 guests
