Colour Code of paint for handle Bar switches
Does any one know the color code or a particular paint from a manufacterer that i can use for painting the characters on my Z900 handle bar switches?
i have done a search through the forum to no avail..
cheers
gary
cheers
gary
Steve Thomas did an article on switchgear restoration in Newzletter#48 someone else was after this too ages ago - I'm still trying to get a copy of the magazine file as it was lost in a disk crash, the printer has one so I'll maybe get it within the next week or two he's supposed to have loked it out for me before the holidays.
Steve recomended Plastikote Super Enamel in Satin Black you can get it in Halfords. Steve does a good job on restorations so if that's what he says it's worth a try.
I'll make this article available as a .pdf for download when I get hold of it.
switchgear
Gary,i got my colours from my local model shop,were close enough,the small tins of humbrol for airfix models with the smallest and thinnest brushes.The black i used was satin black from Halfords or similair shop,cheers
dmltd
Hi Gary
Humbrol all the way - the Pied Pedlar on North Street in Thame has the complete range - brushes too!!
One tip - it's tough getting the lettering pin sharp with a brush alone. My technique is to 'fill' the letter recess with paint on a small brush then wipe off the excess with a fine cloth wetted with white spirit and stretched over your finger nail to form a 'blade'. Might take a little patience mind
- ZedHead
I had one of my switches powder coated in satin black then used the Humbrol enamels, I would be careful scrapping the lettering out that wont be too easy and I didn't have to do that I found it best to slightly overfill the letters and then let it semi dry before wiping over with a smooth cloth dampened with thinners, ended up real good.
P.S. Patience is a virtue.
chris wrote:Steve Thomas did an article on switchgear restoration in Newzletter#48 someone else was after this too ages ago - I'm still trying to get a copy of the magazine file as it was lost in a disk crash, the printer has one so I'll maybe get it within the next week or two
This is now available to download. See the menubar at the top. More will follow eventually if anyone thinks this is a good idea.
- new poster
