43mm brake piston
43mm brake piston
#1 PostAuthor: PAULJAC47 » Sun Jan 31, 2010 7:10 pm
Recently purchased a 43mm piston for my z1b 1975 the one i have been supplied is 43mm diameter but is longer than the one i removed this is 34mm long the new one is 41mm long any ideas what this longer one may be for?
Garn 1
#2 PostAuthor: Garn 1 » Mon Feb 01, 2010 5:43 pm
PaulJac, I'm sure I measured the OD as 43 mm (will check that later!).
Anyway, you may find with longer piston, that you have trouble fitting new pads.
Incidently, I purchased a piston from a brake place, it was exactly the same, except it was 3 mm shorter. I figure it would work, however, I may be in trouble when the pads wear. The piston was from the car, a Lexan dual pot caliper (a lot cheaper than the Kawasaki replacement).
#3 PostAuthor: PAULJAC47 » Mon Feb 01, 2010 6:43 pm
Thanks for that Garn1 sure they are 42mm you say you used ones from a Lexan is that a Ford Model? have you the part number? Cheers Paul J..
GEZ635
#4 PostAuthor: GEZ635 » Tue Feb 02, 2010 12:54 am
Paul, Phil denton engineering sell them for £29 from memory.
Gez
Gez
Garn 1
#5 PostAuthor: Garn 1 » Tue Feb 02, 2010 9:51 pm
PaulJac, the nominal size outside diameter of the Z1 series brake pistons is 43 mm (I checked a few). The replacement piston I purchased, which was about 3 mm shorter, was from a company "Protex" with numbers on box...090P0180 and A11R2H. I was told they were from a model of the up-market Japanese car "Lexus" (not Lexan, as previously stated). There is also a well priced replacement from USA.. Z1 Enterprises.
RegardZ
#6 PostAuthor: PAULJAC47 » Wed Feb 03, 2010 12:22 pm
Thanks Guys
Garn 1
#7 PostAuthor: Garn 1 » Wed Feb 03, 2010 8:25 pm
PaulJac or anyone, there was no mention that the outside diameter of the piston for the Z1B was initially misquoted, or indeed, was correct.
I make it 43 mm, the question talks of a 42mm piston........ I don't mind being wrong! It just needs qualifying for the other innocent readers.
#8 PostAuthor: PAULJAC47 » Wed Feb 03, 2010 10:12 pm
Stand corrected ,just miked them up 43mm ,was going off an advertised dimension thanks for clarifying Garn1..
