do alfa pipes come apart?
Redbeard
#1 PostAuthor: Redbeard » Sun Feb 14, 2010 4:20 pm
Anyone know if the downpipes can be seperated from the rest of the exhaust? So I can heat wrap them individually. Thanking you.
1979 Z1000ST
Thezedsintheshed
#2 PostAuthor: Thezedsintheshed » Sun Feb 14, 2010 4:32 pm
Yes the downpipes do seperate from the rest of the exhaust
it might also be worth you marking them 1 2 3 4 etc on the inside of the downpipes to help speed up the re assembly, some of the downpipes were ready stamped 1 - 4 but not all of them were
It's not broke , just in bit's for a while !
phil churchett
#3 PostAuthor: phil churchett » Sun Feb 14, 2010 4:40 pm
Adam, you will almost certainly find that they won't dismantle easily, road muck, rust etc.. will make the pipes "weld" themselves to the collector. Copius amounts of WD40 will help, [and some patience!]
Redbeard
#4 PostAuthor: Redbeard » Sun Feb 14, 2010 7:38 pm
Thanks guys. I've left them soaked in WD hopefully it will help. I assumed they would seperate but there's no movement whatsoever. Even with the leverage that the pipes allow they don't move, they just flex. Cheers Ted i'll label them if i can get them apart.
1979 Z1000ST
#5 PostAuthor: Pigford » Sun Feb 14, 2010 8:08 pm
Try proper penetrating oil over a few days, then HEAT :wink:
london calling
#6 PostAuthor: london calling » Sun Feb 14, 2010 8:20 pm
The HOT spanner :wink:
Jack
Redbeard
#7 PostAuthor: Redbeard » Sun Feb 14, 2010 8:27 pm
cheers i'll try that too if i have no joy tomorrow. ta
1979 Z1000ST
jimmock
#8 PostAuthor: jimmock » Sun Feb 14, 2010 10:45 pm
Another good trick which sometimes works is...
Get your buddy to drive a transit van at about 90mph. You go in the back and throw the zorst out the back door on to the road. Sometimes the battering around can free the seized items.
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
nigel bessant
#9 PostAuthor: nigel bessant » Sun Feb 14, 2010 10:47 pm
jimmock wrote:Another good trick which sometimes works is...
Jimmock.
Now this might seem far fetched, what about just penetrating it!!
ollie
#10 PostAuthor: ollie » Mon Feb 15, 2010 3:59 pm
don't want to upset anyone but,i bought a brand new alfa in 1983 for one of my zeds and it was one piece.
so they might not come apart unless they made some that did
confused .................i am :D
Redbeard
#11 PostAuthor: Redbeard » Mon Feb 15, 2010 5:45 pm
cheers nige, bit of KY and jobs a good un. :wink: i'll take a pic, it does look like it should come apart, still no joy today though.
1979 Z1000ST
tlc
#12 PostAuthor: tlc » Mon Feb 15, 2010 5:50 pm
I you want some serious heat Adam I have gas bottles in my van.
I can be delicate...........................honest :shock:
I come through Risboro` often on my way home.
Redbeard
#13 PostAuthor: Redbeard » Mon Feb 15, 2010 5:56 pm
Thanks chris, i'll let you know if all else fails. im in aylesbury now just up the road.
1979 Z1000ST
AndyZ1R
#14 PostAuthor: AndyZ1R » Mon Feb 15, 2010 9:41 pm
Try PlusGas as a penetrating oil, it`s much better than WD40, and available from most good motor factors (and some bad ones). Give it a good soaking and leave over night.
Redbeard
#15 PostAuthor: Redbeard » Mon Feb 15, 2010 9:45 pm
cheers andy will try that.
1979 Z1000ST
