Neutral light comes on in first gear any advice
Hi the Z1 I recently bought would not change gear and had a solid clutch. I stripped the clutch and put new plates in. the clutch works great now and gears can be selected no problem. However when in neutral the neutral light does not come on. but when I select first gear it comes on.
Any ideas and advice welcomed.
- london calling
london calling wrote:Don't you mean like an old FART in a CARDIGAN![]()
Come on give the guy a break.
Whats his dress sense got to do with the neutral light issue???
Then again on the other hand Padders it was a bit old fuddy duddy !!!
Jimmock.
Jimmock.
I hate people I don't like !
- paul doran
I don't know if this will be helpful but on my z650 there is a notch in the disc that rotates underneath the nuetral switch when you take the inner transmission cover off. That has to be directly under the switch when you are in nuetral to activate it.
You can see the raised notch on my one (its at the 9o'clock position) on the plate on the left spindle. I wonder if you have mounted that slightly offset??? From Mark
Users browsing this forum: No registered users and 83 guests
