neutral switch
wayno
neutral switch
#1 PostAuthor: wayno » Sun Feb 28, 2010 4:49 pm
think the neutral switch is knackered, checked the bulb and pulled the switch out to check. tried flicking the plunger bit but no light, is there a way to check the wiring back to the bulb before ordering a new one from zpower or is there anywhere else that stock them?
Keefleaf
#2 PostAuthor: Keefleaf » Sun Feb 28, 2010 5:45 pm
I think Cradley Heath are the biggest stock holders,U.K./might be wrong?
Big Fluff
Re: neutral switch
#3 PostAuthor: Big Fluff » Sun Feb 28, 2010 5:45 pm
wayno wrote: is there a way to check the wiring back to the bulb before ordering a new one from zpower or is there anywhere else that stock them?
Wayno.
Simply disconnect the wire at the neutral switch and ground it on the engine casing.... the warning lamp should light up.
If it doesn't then remove the warning lamp cover, remove the neutral lamb bulb, switch on the ignition, and with a voltmeter, check for 12v on the centre contact in the bulb holder. If you don't get 12v then there's a problem with the brown supply wire (same circuit as brake light supply).
If you do get 12v, and the bulb is 100% good, then check the continuity of the return wire to the neutral switch.
Regs, Will.
wayno
#4 PostAuthor: wayno » Sun Feb 28, 2010 7:18 pm
cheers fluff, grounding it worked so got to find a switch next
wayno
#5 PostAuthor: wayno » Mon Mar 01, 2010 6:26 pm
got one on order, just over £6 :D
Kwakdave
#6 PostAuthor: Kwakdave » Sat Mar 22, 2014 11:46 am
Hi Wayno where did you get the neutral switch? as i need one but everywhere says no longer available. Cheers
jimmock
#7 PostAuthor: jimmock » Sat Mar 22, 2014 12:44 pm
wayno wrote:got one on order, just over £6 :D
Now that is a realistic price.
Jimmock. :wnkr
I hate people I don't like !
#8 PostAuthor: z1bman » Sat Mar 22, 2014 2:15 pm
PART NO 131515-003 £11.36 IN STOCK AT CRADLEY
ROZZER
#9 PostAuthor: ROZZER » Sat Mar 22, 2014 6:51 pm
The ones they sell at Z Power arn't the standard ones as they say they are NLA, having said that you can't see it when installed and the replacement is a more robust all metal item.
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
Z903
#10 PostAuthor: Z903 » Sun Mar 23, 2014 10:36 pm
Users browsing this forum: No registered users and 128 guests
