Hi all,
I have put my new fuel tap on, and took the bike for a test ride today, bit cold, anyhow it was runing abit spluttery on the low revs, but when you open her up, its fine,oppisite what it was before, as far as I know the carbs are clean,I had them off a short while back, fuel line has filters, new plugs etc, so wondering if its the carbs or something else..
Andy..
z1000 spluttering on low revs
- Mark Stratton
Hi all,
well, would you adam and eve it, another bl****y plug..they were new, it was the plug on 1 was inermitent, so put another one in, and hey whats you guess it, so its runing ok at the mo, need fine tuning, but it do for now, so what is it with these NGK"S, I know people on here has said they are rubish, I never had any probs on any other bike, only this one, maybe something is doing them in on my bike? I do have a new set of coils, which I will be putting on very soon....
Andy..
Andy..
paulstrees
Plugs
I,ve always used Denso in my A2 with no problems, give them a try, bike seems to run better.
Hi Andy if you get a spare half hour have a read through this.
http://www.z1ownersclub.co.uk/forum/vie ... gs&start=0
Based on the fact that you had a passing tap and its #1 cylinder there is an argument that says that #1 has been flooding....no? Or at best running rich perhaps!
If you read the above thread it would indicate on the surface that there is little difference NOW between NGK and Denso plugs where historically there may well have been.
If you destroy a new plugs or plugs my suggestion would be either that; you are unlucky or that there is another problem elsewhere.
Ignition faults and fuelling issues probably account for a good proportion of plugs discarded as faulty by supply.
You have a new tap now, so maybe as you say its time to look at those coils and possibly measure their supply voltage.
Hope this helps.
(If only to put you to sleep).
Hope this helps.
Hi all,
Just thought I take the z out for a ride today, and guess what, no 4 plug was causing a misfire, so changed it and hey preso, we off again, runing ok, so thats 1 and 4 so far, so, I think I will be changing those coils very soon, hopefully this will help, can anyone tell me if it is possible for the coil to do the plugs in if faulty?
Andy..
Andy..
Users browsing this forum: No registered users and 115 guests
