A1 oil pressure switch cover
02GF74
#1 PostAuthor: 02GF74 » Fri Mar 12, 2010 2:04 pm
you know the ickle rubber cover with wire for oil pressure switch coming out at a right angle - can it be taken apart and then reassambled?
my wire has worn through to a couple of strands!!! and I need to replace it, ideally connector to the contact inside the cap.
otherwise I'll just join the 2 bits of wire, less ideal but will work.
incidentlally, what is the proper collur for this wire - '77 A1.
#2 PostAuthor: chrisu » Fri Mar 12, 2010 2:59 pm
pretty sure its blue........
GUYZED
Re: A1 oil pressure switch cover
#3 PostAuthor: GUYZED » Fri Mar 12, 2010 3:47 pm
incidentlally, what is the proper collur for this wire - '77 A1.[/quote]
It must be the same the Z1000...cos mines blue.
#449
Z1000A2 Z650B1
Garn 1
#4 PostAuthor: Garn 1 » Sun Mar 14, 2010 12:52 am
Agree, wire is blue. It simply lifts off to reveal the connection. I think it just has a female bullet connector to attach the wire to the pressure sensor. The trouble is, it is a right-angle female bullet connector, which I don't think you can buy, anywhere. You may have to modify a straight connector to fit the rubber cover.
